"My shower has stopped working, but the light on the switch is still on!"
Over the phone I got her to turn it off at the mains...
When I get there I had a quick feel of the switch (prime suspect), but it seemed to be OK.. so next is the shower unit.. ?:|
Undo the screws and try to remove the cover... the f*^%er who fitted it had siliconed the cover on and not fitted the shower to the wall securely,,, X(
That was only the start, when I got the cover off I find that the wiring is not quite to regs...
Red to L
Black to E
Green/yellow to N
:O:O:O:O:O:O:O:O:O:O:O
and the L terminal and earth cable are showing signs of a bit of overheating...
So I continuity checked & IR'd (all >299Mohms) the cables and all was ok so I cut back damaged sections and crimped in some new!!
PS the shower was replaced by a pro plumber friend of the son 2 years ago.. and he had the cheek to charge!!
Red to L
Black to E
Green/yellow to N
