phil d
went to a site today to install some temporary security lighting, the electrical work is being done by a large firm from the north west and how terrible it was! The first thing I noticed as I got out of my car, was a lump of SWA coming out of the main building, this went into a 32A yellow(110v) trailing socket, connected to this was a lump of SY cable feeding a couple of portacabins! Inside the building was a temp supply off the recently installed mains, 4 twin sockets fed from a fairly big CU, again temp, no rcd anywhere,not even on the supply to the cabins! There was a CAT 5 cable that was twisted and kinked so badly it was clearly damaged, yet had been left in, and the wall was just about to be boarded, there was also a lot of stud walls, there were holes cut in these, none of which was straight or level, they plan on using fastafix boxes, why?
There were numerous outside light cables emerging from holes drilled in the wall, the Tails protruding, were in some cases over 2 metres long, even the cables left at switches and socket points were almost a metre long, that's some waste!
The property is massive, and has a proper fire alarm, various detectors fitted in the wrong place, I could go on for ages listing the faults, apparently the bill for electrics is 70k! how much of this is spent on the amount of scrap cable due to excessive length I dread to think, talk about a mess.
