I'm after abit of advice
I've run a 25mm 3 core swa 60 metres underground to an outbuilding from a house, the outbuilding is being converted into accommodation. Do I need to put a separate rod in for the consumer unit in the outbuilding or should I use the existing earth in the house? I was thinking a separate rod and just leave the 3rd core unterminated at the meter end. The swa will be protected by a 100ma rcd with 50amp mcb.
