tv cables
paul b b
May 26, 2009
1,751
hello men,
doing a second fix and have a question regarding coax.
in the sitting room the guy has
2x with dish written on
1x amp
1x tv
any ideas what his thoughs are?
he also has some in the atic
and 2 other rooms with cables to
thanks
Hi Paul
Could be 2 are Satalite dish feed in cables
TV poss normal ariel feed in
AMP feed to Amp in loft
Then in loft you have the other end of this to feed into an Amp and then other feeds to other TVs from the Amp.
Hi PaulCould be 2 are Satalite dish feed in cables
Agreed :)
yes it sounds like he is getting sky+/HD and wants to feed the rest of the house with its pictures
a magic eye lets you control the sky from another room,1 end goes into the second tv and the other into either an amp so you can control sky in more than 1 tv location (listen out for the shouts as someone changes your channel) lmao, or into the second output on the sky box. they vary in price
sorry to be bumb here, could someone do a diagram for methanks
Just a note guys that if you do duplex or triplex the other rooms then if you fit screened outlets the magic eyes may not work.
hello men,doing a second fix and have a question regarding coax.
1x amp
1x tv
thanks
So this job is only doing coax? and you are not second fixing someone else's work then notifying it? :eek:
Not quite sure of the point you are trying to make ?:|
Coax cabling work on it's own requires no notification, to tap power for the loft box would be covered by an MWC
