Brace & bit I remember ...but douking irons :C Would they be ...augers ?bit and brace and douking irons.
Douking irons were like a masonary bit with a fat body which you held, you use to hit it the top of it with a hammer, turn it 90deg then hit it again, repeat many many times until hole was deep enough, about 10 minutes to do one hole, remember having to do it at the very start of my apprenticeship then we were given 110V hammer action drills with Masonary bits.Brace & bit I remember ...but douking irons :C Would they be ...augers ?
Nah....I,was one of the first in the UK to own a Makita cordless drill... 7.2V I thinkKerch will know these well ....he still uses them
Got one!was even an Electrician's Swing Brace ...... it had a shallow crank so you could fit it in a floor space & crank it . Hard work due to lack of leverage .
Thats them Roys , they look like the bigger sizes than the No 8 ...10s & 14s perhaps.Deke you just made me go out to an old inheritated tool box as I knew I had some of those horrible vintage Rawlplug inserts.
Look what I found
I have a few spare inserts if you want themI still have one.....
That looks like an early Roman one Specs ....I only ever saw the hex shaped barrels . There was a wedge shaped drift for knocking the jumper bit out when worn but they were always missing . Accepted bit removal was to bang the barrel against the hammer until it flew out & hit you in the eye.I thought everybody had to use these when the power is off while you are extending new circuits??
Sounds like I need to invest in one of these D..R..I..L..L..S.?? (whatever they are?) :C
bush spanner??Locknut spanner
Well I have TWO of them!Go on then. What's the modified mole wrench for? I can identify most tools but not that one.
Poni spotted that one , they brought in MICC pots that had a wedge style of fitting to the cable instead of screwing ...the modified Mole wrench were for cramping the pot onto the wedge .Go on then. What's the modified mole wrench for? I can identify most tools but not that one.
