Hi
I am instaling an underfloor wet heating system (single pump with mixer valve) in my conservatory and want to use a wireless programmable thermostat eg Solus RT500RF or Heatmiser PRT-W to connnect to my gas boiler at the other side of the house to save wiring across the house. My question is can i connect a wired connection from the wireless transmitter to my underfloor pump in the conservatory so that this pump switches on at the same time as my boiler switches on? Anyone suggest a wireless thermostat with a wired output for local connection to switch the pump on. PS. My pump came with a wired non-programmable thermostat which i assume i just need to disconnect and use the same wires to connect to the wireless thermostat if we can. thanks for inputs
