southsparks
Hello.
Has anybody got any idea's as to if any precautions are needed when insulation testing @ say 500 Volts on these new
power points with USB outlets? I believe that the USB outlet part is always available and not switched by the
sockets switch. Would any megger-testing give a false reading, or possibly damage outlet, as in RCD protected plugs?
I have been asked to install some new points with these on new circuits, and I am going to ensure they are RCD
protected, as the requirement to do so are already in force I believe. The new points are for general unsupervised
use by students, so RCD's are a must here. ( I believe that has been a requirement for quite some time already)
Would I be right in thinking a like-for-like swop of an existing 13A SSO with a new USB type socket would not have to
be up-graded to RCD protected, if the circuit is not already? So far, the ones I have already done, are RCD protected.
Thanks, southsparks.
