Uuv Communication System
namer
Oct 17, 2015
2
gaza
i am working in UUV graduation project i have problem to choose the communication media wire or wireless
can i put WiFi broadband or xbee module on small ship over water and connect it to UUV underwater by wire to transmit video from IP camera to PC and receive control signal to arduino from PC and how mach the range can i get it ?? or use wire communication ??
i will put it over water not under but i don't know if it work will or not
depends what range you want as density of water severely effects range of radio waves - I suspect range will be very short indeed, but if you only need a foot or 2 it may work??? Nuclear subs use extra long wavelengths, in the kilometer wavelength range. Random info that probably doesn't help. If you notice underwater robots/subs are generally wired, but they go quite deep and that is partly for power reasons in many cases.
