Update.
There`re actually TWO key locks on the van - the other is on the back doors.
So I took both locks apart ( drivers door easier, since there wasn`t a barrel in there.........). Snapped off the little white plastic tab that operates the lock from the barrel receiver, then refitted the barrel (s). The internal c.locking button unit has been removed, so the ONLY way to open the doors is via the keyfob, or crowbar; unless they know which pins to short on the wiring loom..........
But a small multivibrator feeding a step-up tx with current limiting resistors; fired from a PIR sensor within the rear compartment; now puts a measured 11.6 KV onto six thin metal bars, blocking the way behind each of the three rear doors, with respect to the chassis.
PLUS there`s a wifi P2P camera in the rear; which records movement onto the office PC- and now CCTV covering the drive and the road outside the house.
Belt & braces is to put in a couple of 10W LED floods to the front; with tightly set detection if the property line is breached....................
" If you build it................they will come"....................."Let `em" ] ray O)
