Van Toys
wozz
Distinguished Member
Jan 1, 2009
2,216
Kent
im in the process of purchasing a new larger van and i wish to have a few toys in the new one.
This may sound silly but i was wondering if its possible to have a small microwave in the van (only small stuff some pasta i may bring or a sausage roll or two). ive seen some really expensive 12v microwaves on ebay, or is a inverter the way to go? whats sort of size / price one am i looking at. I also dont want to knacker the battery too much.
Ive seen the railway welfare units with microwaves and such but they may use generators.
Any ideas would be much appreciated.
i have a 800w inverter (well, 300w for chargers at the min, the 800w inverter died)in my van. there is also a second 70AH 12v battery in the van so there is more battery power before battery is too flat to start van. i also have a genny so can easily plug in anything like kettles etc
i have been looking and the compact microwaves for caravans are 500w out put but 900w input! i think i would need a expensive inverter for that!
the idea is to save money by not buying food as i get bored of sandwiches. so it will be a false economy if things get too expensive.
Will putting a load close to the maxiumum output of inverter shorten its life alot?
When I worked away I had an inverter which I could use with my tv, microwave and a fridge.
The fridge was on all the time, the tv occasionally, the microwave now and again, and the kettle often :)
I had it wired into the charging system direct by a local vehicle electrician.
It worked a treat, but make sure you have a backup battery.
jesus! how big was that inverter? was it a little microwave?
i wouldnt mind a little fridge aswel, but bit worried about straining the battery.
did you have a split charging system for the second battery?
jesus! how big was that inverter? was it a little microwave?i wouldnt mind a little fridge aswel, but bit worried about straining the battery.
the battery in mine is connected directly to the existing battery, but if im running loads of long periods, i can switch to second battery only, leaving main battery charged to start engine
hmm interesting stuff, i may have some more questions for you when i get the van and start playing with it.
still deciding on what to have in there...
the best thing is an inverter with an hour time switch - plug your batteyr chargers in and never have a flat battery at a job again. unless the person your with puts flat batteries on the shelf and doesnt put them on charge....
One of our members has a battery saver device that cuts power to the inverter when the battery voltage drops.
Might be M107...........
One of our members has a battery saver device that cuts power to the inverter when the battery voltage drops. Might be M107...........
i have one on the sink, and one on the fridge. never bothered with one for the inverter (i have modded/added loads of wiring etc to my van!)
so thats the reason the street lights go dim then is it :^O :^O
thats just admin busy in his shed again. the entire world dims when he starts something!
even with all the extra stuff in the van, ive never had a flat battery yet. if i didnt have the cutout on the sink/fridge i probably would have many times though
The inverter I bought cost an arm and a leg but was worth it.
Also it did, if the battery level fell below a certain level, cut out. This is a normal safety precauation on all quality units.
Andy what have you done extra with your van electrics? im after ideas now...
