ventilation question
kme
Fridge Keyholder™
Mar 7, 2008
9,984
In the office again.
If I install 2 fans, one intake, one extract - both same make / type / size.
The intake will have a filter on it - the extract won`t!
They`re both much bigger than is necessary, so they`ll usually be running quite slowly..................
BUT
I want positive pressure in the building; therefore I want the extract to run slower than the intake.
I know this and be done with ratio`d drives - but I`m wondering if I can fit a "standard" speed controller to BOTH fans; but add something (resistive??) to the extract fan side, so it gets less than 50% of the output from the speed controller - and therefore goes slower than the intake??
KME
Does it "have" to be positive pressure?
You could look at a "standard" speed control pot and put an offset in yes I suspect.
VSD's would probably be an overkill for the fans I suspect.
However, please remember that the clearance time MUST be verified once the fans are commissioned!
It depends on the detail of the speed controllers you use.
---------- Post Auto-Merged at 19:10 ---------- Previous post was made at 19:09 ----------
Ah, just re-read the OP, you are looking at one speed controller?
Are you going to monitor the level of contaminant?
If you are what will be the feedback loop?
Wasn`t going to mate......
The fans I`m looking at have a max clearance ten times what we actually require - so thought was to put `em on a controller, with a physical restriction on the "minimum"; so they couldn`t tern `em down below approx 150-200% of the calculated airflow requirement.
n.b. Do you have the necessary kit to measure the airflow rates? If so, can you send me a quote for doing it.... (cover the time taken for the LEV doc if you want ]:) ) - and I`ll include it with the quote for install ;)
Not sure what you are trying to achieve Martyn, I can only throw in the following example.
Now I thought the vent engineer mentioned negative pressure but it must be positive I guess, anyway , the printer created a new room for a Digital plate maker and the vent guy put some 6" ducting to outside and a speed controlled fan to create positive pressure within the room to keep the paper dust out from the Print Room adjacent.
Only one fan , drawing air from outside though , not two . Used a rotary speed controller about 3A I think.
Not sure what you are trying to achieve Martyn, I can only throw in the following example.Now I thought the vent engineer mentioned negative pressure but it must be positive I guess, anyway , the printer created a new room for a Digital plate maker and the vent guy put some 6" ducting to outside and a speed controlled fan to create positive pressure within the room to keep the paper dust out from the Print Room adjacent.
Just to add that it works a treat . On the other side of the doors is the Print Room and everything in there has a thick layer of paper dust on it but in the Platemaker Room there is no dust .
Thanks Sandy :x
The building concerned is one room - needs the air to be refreshed due to the (side effect) production of CO2.
Thanks to the snakey-hipped one, we know the fan requirements.
It only NEEDS to be a 5" - but the intake needs to push more air into the room, than the exhaust removes - so only the clean air is being brought in.....
Erm......actually, having just posted that - do we NEED to exhaust; when we have a 2 sq. Metre doorway (with plastic curtain thingies) that is always open during the day ????
HTH
230Volts is no good unless its three phase, I don't do those crappy little single phase output invertersIf you haven't got a fan yet, get a 3 phase one and make sure its 6 wire so we can connect it in delta for 230V 3 phase on the motor and use a single phase supply to the inverter
OK - but see above.
1. Is there a requirement for an exhaust fan?
2. If not, what advantage is there to having a 6 wire on a drive; over a basic speed control? Given the comparative small size of the fans, I don`t think its necessary to relate fan speed to air quality - if they have speed control, with the minimum air movement preset.
3. If I DO need mech. exhaust; could I use a fan slightly smaller then the intake; to provide the differential?
4. What are the cost differences? `cos I`m going to be asked??
