rjlee
- Mar 19, 2022
- 2
- 0
I've recently resurrected our Veritas R8 Plus after leaving it powered off for a few years. After replacing the battery, everything seems to be working fine. I've bought a keyswitch, which I've wired into an empty zone (Z6). I've tried to follow the instructions in the manual to add it, but I get a brief 'access denied' type tone. I'm pretty confident I'm in the programming menu correctly as i can run a walk test, but trying to change any other settings results in the 'access denied' tone.
To enter the programming menu I do:
1234 + PROG (I reset the engineer code to the default)
The zone lights then all turn red as expected from the manual and I can run a walk test and when I activate the key switch, Z6 lights up
Then when I try and set the zone to be a keyswitch when in programming mode:
168+PROG
After pressing 16, I then hear the 'access denied' tone from the keypad.
Could someone advise ? I read about a 'boss code', but given I think I've got the 'engineer code' and am able to enter the programming menu, I assumed this would work ?
Thanks.
168+PROG
Thanks.
