Voltage Question Regarding Different Size Systems/solar Pv Projects..
Bass Cadet
Feb 9, 2015
Hi all...
I have a hypothetical question regarding different size solar PV systems:
[SIZE=11pt]If we have 4 hypothetical projects of different sizes;
100 KWp
400 KWp
750 KWp
1 MW
[/SIZE]
Assuming I'm using 250W panels:
For example [SIZE=11pt]100KWp[/SIZE][SIZE=11pt] – 400 modules @ 37.4V (Voc – open circuit voltage) @8.31 Amps and tied into a 240V Mains[/SIZE]
[SIZE=11pt]What is the voltage of the electricity generated of each project? Is it the same for all 4 or different?[/SIZE]
Any help/advice appreciated
Canoeboy said:
Depends on the design
Is this a homework question ?
The design is basically (for arguments sake), ground mounts/solar farms with modules connected in series...ie all the system sizes are a series circuit. Does the produced voltage remain the same? From my details above I've calculated ~ 30V (DC). So when arrays are all in series then the voltage remains the same despite the system size (Kwp)...is this correct?
No, it's not  a homework question. Just trying to figure out a problem a friend asked.
makes no difference to AC outputs in compliance with g83 / G59 requirements. Panels - think of these as solar batteries, if you join 20 batteries in series what happens to the voltage and ampage???
