Just got back from a call out to a flat for no power at all.
Reset the rcd and tested = no fault present. spoke to the home owner what happened when the lot went off.
"I held the E cig usb charger plugged it in to the un-switched socket & massive flash & bang, resulting in no power anywhere"
So here it is the offending item purchased from a well known high street chain.....
Note no BS or CE markings/numbers on the labelling
http://i83.photobucket.com/albums/j293/gazjothomas/20130910_164546_zps1425e68f.jpg
No other markings at all
http://i83.photobucket.com/albums/j293/gazjothomas/20130910_164558_zpsd4b40e6e.jpg
http://i83.photobucket.com/albums/j293/gazjothomas/20130910_164613_zps480ce9e3.jpg
And here is the problem
http://i83.photobucket.com/albums/j293/gazjothomas/20130910_164649_zpse6f504c7.jpg
http://i83.photobucket.com/albums/j293/gazjothomas/20130910_164703_zpse344413e.jpg
http://i83.photobucket.com/albums/j293/gazjothomas/20130910_164726_zpsf73090c2.jpg
http://i83.photobucket.com/albums/j293/gazjothomas/20130910_164736_zpsc737bde4.jpg
More cheap rip off carp.
So be careful of what you buy & check it first..........as it doesn't seem to matter where you buy from these days, theunsafe kit is getting through to the big high street stores.
