Dairyspark
Hi guys,
So I do a lot of work in agricultural settings and currently doing a new large dairy unit. 50 or 54 point rotary with everything from cooling compressors to vacuum pumps and beyond. Now my question comes in the form of this
The plant water heater is huge, it contains 3 x 6kw elements which consists of 3 x 2kw each having a phase and one common neutral, does that make sense?
Now all the elements are linked together so L1 of element one is linked to L1 of element 2 and then to element 3 so each phase has effectively 6kw attached to it and all the neutrals are just linked together.
Now my understanding of this is each phase will draw 26A and since they are all returning down one neutral line does that mean that it’s getting 78A back down the neutral? Now if this is correct then surely that’s absolutely no use to anyone as I’d have to supply it with a 16-25mm² cable to carry the neutral current. Surely this is a terrible design?
Am I being stupid and not understanding basic electrical theory or is this the most ridiculous water heater know to man
I have attached a picture of the offending water heater to show the size of it
Cheers
Bobby
Cheers
Bobby
