what cable
conorfalvey
Feb 12, 2012
6
I am about to first fix an orangery which is mainly glass down to about a metre then it is a block wall all around and a concrete floor, possibly with under floor heating. Sockets are required in all corners of the room and a switch next to a door leading outside.
What is the best way to wire this, swa under the concrete or for the sockets is it possible to go horizontal around the room as best as possible and with links of swa, or is there another cable to use.
Would it be possible to use galv conduit ? Makes future works much easier
How about that orange covered cable with pots on the end. It might blend in well :slap
Oh I dont think I'd recommend plastic conduit in a nice sunny hot environment unless you want call backs to rectify why it has bent all out of shape
and have you gave it any thought to IP ratings of accessories with all the water that will probably be sprayed everywhere.
I am about to first fix an orangery which is mainly glass down to about a metre then it is a block wall all around and a concrete floor, possibly with under floor heating. Sockets are required in all corners of the room and a switch next to a door leading outside.What is the best way to wire this, swa under the concrete or for the sockets is it possible to go horizontal around the room as best as possible and with links of swa, or is there another cable to use.
Underfloor heating will probably prohibit your under floor suggestion as a cable run. There are two types of wiring system that will cope with the environmental issues you have here, fauna, heat, humidity and abuse from workers using heavy handed I don't care attitudes.
Armoured, or galv conduit, run into ip rated outlets, plastic conduit will over time become supple in the heat and will sag, looking really bad.
Pyro is a no go unless its the fully sheathed type, in which case would probably be my choice, but having said that most of the armour cable I purchase these days is up to the job.
An orangery is normally a brick built extension, with a flat roof and a conservatory style glass lantern on top....
---------- Post Auto-Merged at 23:25 ---------- Previous post was made at 23:07 ----------
I've worked on quite a few that were 'under construction' the sparks normally just go horizontally from socket to socket using galv capping straight on to the block work before bonding/plastering takes place.
An orangery is normally a brick built extension, with a flat roof and a conservatory style glass lantern on top....---------- Post Auto-Merged at 23:25 ---------- Previous post was made at 23:07 ----------
That is often the problem,every rewire I do is designed to be rewired without the need to smash hell out of the building.
Good point Mantor, i spose you could chase the blocks out first, creating a duct to pull new cables through.....
P.S, I wasn't the 'sparks' ;)
I was thinking more Victorian Orangery where plants were brought in and fruit trees etc were grown, as opposed to conservatory type rooms.
I think the Galveston capping would be a good option if buried in the wall but can the capping be plastic
And yes it basically is a posh conservatory,
Thanks for the help
Posh greenhouse
Recent discussion by NIC on running in low wall cavity, and they see no problem if fixed to inner wall at top before sill goes on, very handy.
