I was called out to a house of an old lady complaining that electric light circuit was tripping after renovation work. Carried out checks found low resistance between live and eath wire to kitchen. In the back room found switch live open circuit easily rectified witha smart bulb. But what to do with earth wire ? No access to inspect laminated flooring above tried endoscope camera through one of the class 2 downlighters could see but not access junction box. The class 2 down lighters only used live and nuetral as you would expect and did not trip with earth wire to this circuit disconnected, should I shrink sleeve earth it and leave disconnected or insert resistor and connect to the nuetral?
