I have had fitted Solar thermal heating. Unfortunately instead of extending the controls to the landing they have left them in the attic, this means i cant see what temperature the boil has warmed too or even switch off the system with out going to the attic.. They have used a Grundfos UPM3 HYBRID pump which connects to the controller i wish to move. The 3 core power is easy to understand and extend however there is also a a signal cable (described as this in the instruction Signal cable, FCI, 3 wire, with return) https://www.navitron.org.uk/pwm-pulse-width-modulation-cable-for-upm3-high-efficiency-pumps-and-pumpstations?gclid=EAIaIQobChMIg6KVq5Kf7wIVxO3tCh2i1wfIEAQYASABEgIBWfD_BwE This is the wire i dont understand. What is the correct cable i need to purchase to extend my signal cable?
signal,
signal,
