erm surely thats cause its been unscrewed by you so the socket would be hanging off.
And probably no RCD's in sight - they'd be tripping constantly, otherwise.And Sellers has itapart from others who knew and only aluded to itYes, there's no High Integrity Earthing anywhere in the property,,,, even in the server room
Only if Noz has got a double socket in the van with two earth terminals on it!Oh could you post a pic of how it should be?
You're right, of course. Fingers moving faster than the brain tonight. headbangRCD would still trip even with high integ earthing.
They have two CU's upstairs fed from one unprotected 16mm T&E "sub main" via henly blocks directly off the tails and then a DP henly block and tails to the CU'sAnd probably no RCD's in sight - they'd be tripping constantly, otherwise.
Have a look at 543.7 in general and 543.7.2 in particularI know this sounds stupid but as I'm a student I don't get it. Is it because it's a special location so the requirements are different when running cpc's?
Its high integrity earthing, in areas where the are a lot of items that leak current to earth naturally it is needed. PC's generaly leak some current to earth, so imagine a computer room with 30 PC's in. It all adds up, so a bigger cpc is installed. I am not 100% clued up as to why, but I guess its to safely dissipate the current.I know this sounds stupid but as I'm a student I don't get it. Is it because it's a special location so the requirements are different when running cpc's?
No it dosent...I know this sounds stupid but as I'm a student I don't get it. Is it because it's a special location so the requirements are different when running cpc's?
who you callin' competent.?!by a "competent" person
That's exactly the reason I put it in hereNo it dosent...![]()
THIS IS THE STUDENT AREA...
for people like you to get your head around things....
:Salute
It would be stupid if asked by a "competent" person in the inspection & testing area though!!!
:innocent
c'mon, keep up, we are harmonised now, and all our faults are at the same volts and current too, so when you get a shock you say mon dieu!I suppose it makes perfect sense, loose you earth, and your PC case becomes 230v.
But I don't need a high integrity earth in my house and it's ok if I lose an earth connection and my PC case becomes live?I suppose it makes perfect sense, loose you earth, and your PC case becomes 240v.
