I have always learned a general rule of 3mA per item of IT kit, therefore a max of 4 X double sockets on any one 30mA device.
As this is in the student area, and hasn`t been picked up.the cpc wire is longer whilst not being a problem it's bad practise????
First thing to remember is that high integrity earth is not just a ring final requirement..Hi integ earthing is something I have never seen the point in personally, if you do all your dead tests and prove its a ring, what is the point ?! I'd be interested if somebody could actually give a decent reason.
Actually it is relevant I think...I did fit a batch of twin 13A sockets once, that no matter how hard I tightened the connection screws on the back of them they would slacken off after about 6 months. Had to use a spot of stud lock on the screws in the end. No more problems after that but weird. We put it down to rubbish manufacturing and bluffed about 50Hz being the resonant frequency of the screws. Not sure how relevent to this thread, sorry if I have digressed it a little.
I don't think its over the top. Its what the whole electrical world is based on. being fail safe. Faults occur and measures are put in place to prevent injury and damage. Same goes for Hi Integ earthing its a form of fault/shocl prevention.It seems like massive over kill to me, again if your tests have been carried out correctly and you installed the circuit well, what's the point In dragging in an extra earth to do the job of the earth that's already there, earths don't just disconnect themselves. I understand the point, I just personally think its over the top. Maybe it's a better safe than sorry.
John,What is with the lug on the right hand side of the box?? looks like the screw is still in place?? Has it pulled through the socket front plate??john..
That would depend on the type of thread lock that you use,, Loctite make many different versions for different applications... and you can pretty much free any thread locked screw/nut, you just have to use the right methodHi Paul, I know exactly what you mean, so loctiting them as has been suggested previously, is a VERY bad idea.. You will merely never be able to tighten them, you have in fact then, to all intents and purposes made them "inaccessible"
john...
you disappoint me here John,Loctite make many different versions for different applications
