Hi, bit of guidance needed.
My existing light fitting has four connections in the joining block, labelled live (which has 3 brown wires connected), neutral (with 2 blue wires connected), earth (3 green and yellow wires connected) and something I can't make out but the switch cable is wired into it ( blue with brown tape). The new light fitting has 3 connections, labelled live, neutral and earth.
Also the existing block has separate holes for each wire in each connection, the new one has only one bigger hole in each connection.
Where is the correct place to put the switch live wire? I have pics but I can't see how to attach on this forum.
Thank you for reading!
