Ha im just trying to get this in plain english.
Lets say I have a typical bungalow
I have
shower on 10mm
cooker on 6mm
two final rings on 2.5mm
two lighting on 1.5mm
one outside socket on 2.5mm ( for garden stuff)
Lets say im using a 10 way wylex board loaded with
100A Rated Main Switch
2 x RCDs (1 x 80A
1 x 63A
I understand the cable calcs and the rating of the mcbs but what about the rating of the rcds?
How do you know what goes under the 80A and what goes under the 63A?
If you like you could tell me what you use
these are the mcbs
3 x 6A, 2 x 16A, 4 x 32A, 1 x 40A
Ok i would put the
80A RCD
shower on the 40A
final ring (1) 32A
lighting (1) 6A
63A RCD
cooker 32A
final ring (2) 32A
lighting (2) 6A
outside socket 16A
Just trying to understand how you know what rcd to use.
thanks
I have
shower on 10mm
cooker on 6mm
2 x RCDs (1 x 80A
1 x 63A
these are the mcbs
Ok i would put the
80A RCD
shower on the 40A
final ring (1) 32A
lighting (1) 6A
63A RCD
cooker 32A
final ring (2) 32A
lighting (2) 6A
outside socket 16A
thanks
