andrewedwardjudd
Hi I was having a go at explaining grounding and after some discussion and a few arguments I came up against some problems because the internet was providing what appeared to be a totally wrong conceptualisation of the nature of our supplied power supply.
Ie many professional electricians are talking about an electrical flow to ground or neutral. That must be conceptually wrong since we are talking about alternating current?
As far as I can see we do not get a shock from a properly wired neutral or earth because the surface area of the so called live conductors exposed to air is very small compared to the very much larger surface area of the so called neutral/earth bonded conductors that is exposed to the air?
So in an unusual situation where the neutral was not connected to earth at your location, and the property was some distance to any other grounded neutral or it was unusually dry, and there was a large appliance with a live unpainted chassis or unbonded live sink that was near you, it seems to me you would get a shock if you touched neutral?
I am right or am I talking rubbish?
Cheers
Andrew
Cheers
Andrew
