Best not :innocent
I gave this a little thought and think it goes +ve 25 times per second and -ve 25 times per second.................well you learn something new everyday.... it goes +ve then -ve 50 times a second..... wow Thats what them ozzy rockers were on about all this time....
I am surprised that you are directing this at me. Some of the other replies made on this thread show a general lack of understanding from people who say they are qualified.have tried sensible replies and sarcasm and he still goes on and on and on..... just thought I'd throw my 2p worth (and thats all its worth) in. I remember installing a massive battery and generator system in an exchange and no I didnt try it but reckoned I would have felt something uncomfortable had I touched the -ve at the battery. But don't lets go off at a tangent this thread is bad enough as it is!
Evidently the subject is sufficiently complicated that many electrically qualified people do not understand what appear to be simple electrical principles. Your comment is totally unjustifiedTBH I was trying to keep it simple or this guy'll tie himself up in knots (unless he's a troll that is)
It is 50 cycles rather than 50 half cyclesI gave this a little thought and think it goes +ve 25 times per second and -ve 25 times per second.................![]()
but not always outside of the substation,The beginning idea of the thread was to resolve the nature of the neutral and find out why we get shocked by a live so that unquestionably I know the answer. My theory about the shock pathway going via air seems to have been debunked, but i was still wanting to know why the live was hot
In my own mind i am beginning to be satisfied i know what is happening
The variations on wiring a house are not important.
In the UK NZ and Finland, neutral is grounded and thus there is an easily available potential circuit which can be completed via your body if you touch 'live' even if you do not directly touch neutral to form a circuit.
In either country if you touch neutral there is no easily available circuit that be completed to form a circuit back to the substation.
I was asking for a fairly simple explanation for a typical functioning mains system. I said at some point that the earth and the neutral were effectively the same thing and said many posters were labouring the flow of current via earth.but not always outside of the substation,
there are a lot of mad assumptions being stated in this thread,
you really really need to understand that the differing earthing systems in use in each country make a massive difference to how the neutral reacts in any given situation.
My comments in red...Hi I was having a go at explaining grounding and after some discussion and a few arguments I came up against some problems because the internet was providing what appeared to be a totally wrong conceptualisation of the nature of our supplied power supply.
The internet is full of idiots spouting gibberish, so this statement is correct.
Ie many professional electricians are talking about an electrical flow to ground or neutral. That must be conceptually wrong since we are talking about alternating current?
Direction of current flow is irrelevant, you are asking about shocks. A sufficiently large DC supply can give you a shock whichever way round you connect two parts of your body. AC will give shocks on either half of the cycle. But in both cases you need a suitably high potential difference between two sources for a current to flow. e.g. 50v AC pd will give a shock but is considered a maximum limit not to be exceeded during fault conditions prior to disconnection of the supply.
As far as I can see we do not get a shock from a properly wired neutral or earth because the surface area of the so called live conductors exposed to air is very small compared to the very much larger surface area of the so called neutral/earth bonded conductors that is exposed to the air?
An example of the internet full of idiots spouting gibberish! Surface area is irrelevant. Potential difference between two simultaneously accessible points is the cause. If Neutral and Earth are at the same potential.. There is NO pd.
So in an unusual situation where the neutral was not connected to earth at your location, and the property was some distance to any other grounded neutral or it was unusually dry, and there was a large appliance with a live unpainted chassis or unbonded live sink that was near you, it seems to me you would get a shock if you touched neutral?
Your question only says the neutral not connected to earth at the load end. one has to assume that the supply is still connected correctly? Or in your unusual situation the property owner would have found none of their appliances were working as the circuit is not complete. Other than that, any time you split open any part of a circuit Line or Neutral there will be one live conductor (line or neutral) with a higher potential to the other half of the break in the conductor, thus a risk of shock. Which is why the Neutral IS a LIVE conductor.
I am right or am I talking rubbish?
Cheers
Andrew
I agree.My comments in red...
Primarily for any students who may be reading this posts
As you answered your own question on the first post..
yes you are talking rubbish.!
No further comments
:shakehead
:coat
Sufficiently large potentials and you can get a shock across almost anything....I note I can get a significant signal from a simple testing screwdriver if i jump into the air so I am still not entirely satisfied i cannot get a shock from for example humid air in a bathroom. Also as regards some electrians standing on insulated mats with boots to show apprentices they are not shocked it must be true that each person has a different ability to conduct electricity via their skin and even their internal electrolytes etc, where some skin types are noticeably much more oily or moist or prone to sweating than others and a drier person who habitually does not drink sufficient water will be more salty and be a better internal conductor but perhaps a poorer external conductor. It could be quite complex. I do not know.
OK. Which currently installed UK methods have a neutral that is not connected to Earth by a common connection?Earth is NOT common to neutral
when will you stop saying it is?
This is where you are fumdamentaly wrong, it is all dependant on the distribution system as to how earth and neutral relate to each other.
TT for a start.Neutral is connected to an earth mat at the substation, and earth in your house is a local earth rod.OK. Which currently installed UK methods have a neutral that is not connected to Earth by a common connection?
Thanks.TT for a start.
Nsutral is connected to an earth mat at the substation, and earth in your house is a local earth rod.
No direct connection between them, just a lot of erm earth (as in mud) between them.
