Called to a "immersion circuit not working so no hot water, plumber refuses to come back as it's an electrical fault"
The circuit was working & live when I turned up, the plumber had recently changed the element & stat (wrong stat in use you'll notice), he didn't connect the line conductor into the terminal when he screwed the terminal down but it was touching the terminal so worked when he left............the rest is history as they say
