Most are low power 'relays' so if you're close to them and with a still fairly decent signal from the router they are good (in terms of throughput speed) They all make the device show strong wifi even if the actual throughput may be crawling.
Most effective in drywall rather than metal backbox in blockwork (and they don't last forever so as long as the customer supplied them its good repeat business)
Mesh network systems or larger multi aerial (relay) Boosters in loft space or cupboards may be a better solution
