Windows XP disc help
Cirrus
Distinguished Member
Oct 17, 2008
1,114
Gloucestershire / Cotswolds
Have lost my original XP install disck and need to format my 2 pc's. Does anyone have a copy they could spare (either on disk or to download)?
The original disc was linked to your machine - a copy will flag windoze validation system, and decide its a counterfeit. Windoze`ll ask for a new validation key :( :(
Last I heard, Mockrosoft were charging
some pc have a built in factory reset, u could be lucky
my mate had same prob, he got a xp disk it worked and still does but now its coming up with illegal version
The original disc was linked to your machine - a copy will flag windoze validation system, and decide its a counterfeit. Windoze`ll ask for a new validation key :( :(Last I heard, Mockrosoft were charging
Seems there is a limit on how many times M$ will let you reinstall XP, I had two pukka keys die on me after 6th or so reload, which is carp considering how many times you have to start from fresh as XP slows down after a few months
Yes Vista "rather stick pins in my eyes", however I have been using Win7 eval as a media centre for a while very good, so now have bought the release copy
It's the key not the disc that is relevant, all the disc's are identical, so if Cirrus still has a valid key any disc will work, I'm not even sure the discs have any copy protectionBTW this should be in the Computers section - ADMIN?
Moved.
The Godfather
its bad really u paid for the software when u get the pc it should be guaranteed for the computers life
Don't think that is quite the case.
Don
You have to phone the Tel. No. on the screen, and they will give you a new code.
If they ask why, you just tell them.
you also need the correct release ie sp1,2,or 3.
had this prob but rang ms and told the tale and they gave me a new key over the phone.
ms will flag up illegal if not registered but you can use, believe they only stop upgrades. Try fleabay might get cheap oe with key
