KillerWatt
- Nov 11, 2008
- 54
- 0
Im sure the nazis said that (or something similar) about enigma.......You should have installed DD-WRT, and then jacked the transmit power up to 100mWThey were more than likely using WEP security, crackable in as little as 10 seconds depending on the password used.
You sure weren't cracking WPA in any reasonable time frame (even if the user did use a standard word for the password), and you sure as s**t ain't cracking WPA2 encryption in your lifetime.
I'm sure if you have the processing power of a Cray supercomputer, AND the user has used a simple word as the passphrase, AND you have a suitably precompiled hash table (which would probably be around 50GB in size).....you might crack it inside of 2 years or so if you leave it running 24/7Im sure the nazis said that (or something similar) about enigma.......
Make of it what you want, http://en.wikipedia.org/wiki/Wi-Fi_Protected_Access but the way I read it i dont think anyone will bother hacking your wi-fi if you have either WAP or WAP2 unless your part of MI5. Your more likely to get hacked via having poor firewall and anti-virus.I'm sure if you have the processing power of a Cray supercomputer, AND the user has used a simple word as the passphrase, AND you have a suitably precompiled hash table (which would probably be around 50GB in size).....you might crack it inside of 2 years or so if you leave it running 24/7
Oh I dunno, my youngest sees continuous 11MB/sec transfer rates from my NAS box (hardwired) to his desktop machine upstairs - which is faster than what a 100Mbit wired setup will achieve.Anyway wireless still has not got the bandwidth and reliability of wired even if you use Tri-band units etc.
8 bits = 1 byteno idea how 11MB/sec relates to 100Mbit so you see this is IMO what pc people do to BS if they dont have a good arguement, keep changing the measurement points......
All depends on your hardware as to what's best.I just wanna know what is better for the normal person, not the technonerd.
Sorry lost me on that one you've got a Nas Box hardwired to a desktop where is the wi-fi in this setup? or is it me being thick.Oh I dunno, my youngest sees continuous 11MB/sec transfer rates from my NAS box (hardwired) to his desktop machine upstairs - which is faster than what a 100Mbit wired setup will achieve.
Sorry Ian, that was a bit misleading now I have read it back.Sorry lost me on that one you've got a Nas Box hardwired to a desktop where is the wi-fi in this setup? or is it me being thick.
The punter could say the same about electricians, plumbers, mechanics, etc.but I think it just hardens my point about PC people trying to blind us non types with science.I did understand your point, but for someone in a shop (example) listening it would be pure gobbledegook would you agree.?
Wireless 'N' kit is 2still, it just strengthens the argument pro hardwired,! else change all your kit and still get slow speeds, and the risk of someone hacking you.!
(remember, the enigma code was IMPOSSIBLE to hack!)
Unless you have prior knowledge of Steptoe's hardware capabilities, I'd say that's a rather bold statement to make.Nothing to do with your router or set up.
Unless you have prior knowledge of Steptoe's hardware capabilities, I'd say that's a rather bold statement to make.If you take the statement out of context then yes it is, but take it with the other previous sentences and it makes complete sense.
Forums are not a place to qualify and joust your intelligence against others.
You know what I described is probably the reason.
In any case its the obvious first try before going deeper, isn't it?
These readers are electricians not computer geeks, which is why they ask the simpler questions on this forum hopefully and patiently expecting simple step by step intelligible answers.
Thanks for that calltronicsApplaud Smiley, I thought I'd asked a simple question but I got lost after about reply 2:_|. Correct me if I'm wrong but the general thoughts apear to be put up with the cable modem.These readers are electricians not computer geeks, which is why they ask the simpler questions on this forum hopefully and patiently expecting simple step by step intelligible answers.
I don't do pi$$ing contests, I grew out of that by the time I left school.Forums are not a place to qualify and joust your intelligence against others.
Steptoe's original query implied that he only noticed the problem on one particular PC (his "garage" PC).You know what I described is probably the reason.
