Wiring basic bathroom extractor to timer
Feb 4, 2016
5
Hi,
I've got an old bathroom extractor fan that doesn't have a timer on it - it's just attached to a switch on the wall. I'd like to get rid of the switch and wire it up so it will come on when the lights do, then stay on for a few minutes after.
I know I could buy a new fan, but that would mean a lot more work.
I've read about how the timed fans work, with the permanent and switched live - I assume there's a "switch" I can buy to retrofit that functionality to my non-timed extractor.
Really, I just need the name of the part - I don't know how to phrase what I want into something I can put into google, but any advice is welcome.
Thanks.
There are no direct retrofit timer modules for extractor fans (except for the Icon range) however you could do it with other parts which would cost far more than a replacement fan and any rewiring that would be required.
If there's never been a timer on it, you may not have the 3-core & Earth cable it will need.
How about a humidistat fan instead?
Might be able to change the switch to a fused spur if there isn't one already & if it's in a suitable area.
Yes there are, man rose make a separate timer module which allows timer functionality to be added to any fan, they fit on a single pattress.
If if you look at the Honeywell sundial wiring plans pack you'll see a diagram where the same unit is used to add a timed pump overrun to a boiler system without an internal overrun facility.
I've not looked yet, but if it has a 3-core+earth cable, I'll just replace the fan.
I'm expecting to find 2 core+earth, and in that scenario, I wanted to wire it up like this:
Fan
[MAGIC] --- Permanent Live
Lights ( Switched Live )
Where 'magic' detects the switched-live from the lights, then uses the permanent live input to keep the fan on for a few minutes after the switched-live goes off.
It's the name of the 'magic' part that I'm after. Surely there's something I can buy to do that job ( it's just the same thing that's inside a normal delayed-off fan, but as a separate unit ).
Easiest solution is to replace the switch with a time lag switch. http://www.toolstation.com/shop/p83921?table=no Other than that I would suggest a new fan as the next easiest option.
Thanks, but I'd prefer it if it was automatic ( without going to the trouble of replacing the wire to the fan, as it's hidden behind the tiles, so I assume I won't be able to replace it easily ).
Fan
One option for your magic is: https://www.tlc-direct.co.uk/Products/BGDT20.html But does seem expensive when a complete timer fan can be got for £20.  http://www.screwfix.com/p/manrose-xf100t-20w-axial-bathroom-fan/15927
Doc H,
Ooooh,, so there is.... :coat
Every day is a learning day :)
