Can anyone suggest how they would wire emergency lights so that when they are tested it will not switch off the normal lights.
The emergency lights are to be incorporated into the standard lights. Ie one unit. They are recessed grid type lights in a classroom.
So during normal operation the standard/emergency lights will be on and then during power failure will switch over to emergency. The standard lights will be on normally and then during testing of emergency lights will remain on.
My concern is if the emergency lights are to work as a standard fitting and all other standard lights are to remain on when tested how the hell can you tell if they are in test mode? Led maybe?
This is what the consultant has requested.
