apdevelopments
- Joined
- Feb 4, 2011
- Messages
- 4
- Reaction score
- 0
I am having alittle trouble trying to get to grips with putting power to my garage which is next to my house.
I already have power to my garage via a 60ft length of 2.5 armored cable.
The run starts from the consumer unit in the house and is protected with a 30ma RCBO.
But I would like to fit a new consumer unit to my garage and bring it up to 17th edition.
I would like to use this job for my first assessment with elecsa. Yes Im a newbie to all of this and I am still at college. :innocent My garage will have different circuits including a ring as I want to build it into a wood workshop.
Anyway. First of all I know that I need to change the RCBO in the consumer unit for a time delayed unit as I will have another RCD in the garage.
I also know that I am aloud up to 3% voltage drop in the length of cable as I will be fitting a lighting circuit. No problems here as there is only 1volt drop according to my meter readings.
The big question is DO I NEED A EARTH ROD rammed into the ground next to my garage and take away the earth run in the armored cable. Making the garage into a TT system?
What is the max length of armored cable aloud before I need a earth rod? as I can shorten the armored cable run to 48ft by re routing it.
Any help would be great as i dont want to sound a plant pot.
Many thanks
Many thanks
