This is a new EV charger CU, right outside a customers front door .........
.View attachment 11542
Oh and yes, there's a sticker on the other side too!
I reckon I could get one or two more stickers on that perspex hinged front cover!? Guinness
I saw one at one of my customers....
Have the regulations stipulated a whole bunch of EV charger labels and warnings that are too big the fit onto the average equipment size??
Jeez, you lot a hard bunch to satisfy, if people don’t comply you pick up on it and now when they do comply you pick up on it!
:C
But you know better, we grew up in a world of common sense, today everything is spoon fed as people can not think for themselves.Covering small boxes in labels which sometimes state the obvious isn't necessary
i refuse to put the dual colour label on my installs. FFS it’s about 18 years since the colours changedThe pointless sticker award goes to the mixed wiring colour one, if you can't work out there's colours to two versions of BS7671 you shouldn't be meddling with it in the first place and second has to be the RCD test button sticker for the most ignored.
Which means anyone under about 35 that has done only new installs, will be totally confused when they see an old install with this strange old coloured cables.i refuse to put the dual colour label on my installs. FFS it’s about 18 years since the colours changed
But if you are competent you should know that anyway so agreed it is rather pointless.
Yep, if you don't know what the wires are for/do then you shouldn't be fiddling with it. Simples. Get it wrong, you probably die, Darwinism!
