buckle1982
- Sep 8, 2020
- 15
- 0
Hi, we have a Zanussi ZOD35511XK oven and we had a power cut on Sunday. Since then the main oven won’t heat up (the light goes on & the fan goes on) but it won’t heat up & I think it is to do with the fact that the ‘end’ arrow button seems to be stuck on the same time as the actual time, we cannot press the (-) button to reduce the time to get rid of this, cancel this setting. We have turned it off at the mains and back on again & from here we have set the clock as you are meant to, which is fine... but then we have a look at the ‘end’ arrow button it has the same time set as the clock and therefore isn’t allowing the oven to heat up! Any ideas / suggestions are most welcome!! Thank you
