Interesting viewpoint ext - could you elaborate!I couldn't imagine any self respecting electrician, not doing live tests...
Good point about changing the light fitting.DaveTesting lighting is not easy but I think it should be done. I usually do. I have them adaptors although I have not used them yet. Surely if you change a light fitting it is easier to do a loop test than take the lid off consumer unit to do a r1+r2 test.
Batty
I think, not got notes with me right now, that you have to do live Zs for TT systems - you can't use calculation.Zs live Testing - does everyone do it? Or do you use a calculated Zs instead
But you still need to take the fitting apart for R1+R2.Good point about changing the light fitting. I've been thinking about the question on the lines of PIR's and personally see nothing wrong in the Ze + R1 + R2. In my experience my ze+R1+R2 reading tends to be slightly higher than the Zs - and if that's within spec I'm happy! I have never found a socket which passes by the Ze + R1 + R2 method and fails the live Zs.
I've been thinking of getting some of those lighting adaptors. Seem like a good idea!
Cheers
Dave
Loop testing is all right through dimmers if you have a meter that only puts through a low test current through it. It the r1 + r2 I find doesn't work.Just remember if you do zs on ligthing,make sure there isnt a dimmer connected. They don't like it much- strangely.......
welcome Guiness DrinkZs live Testing - does everyone do it? Or do you use a calculated Zs instead
can see NO reason why you cannot easily do Zs??? ?:|
Applaud SmileyJust remember if you do zs on ligthing,make sure there isnt a dimmer connected. They don't like it much- strangely.......
[8] being a Cow with a chainsaw!!! ; \
- no tester
- batteries in tester flat
- no stepladder
- no arms
- being drunk
- blindness
- vertigo
