Hi
I have an Ideal Logic 15 boiler installed last November. Programmer is ST9400C and wireless thermostat Honeywell DT92E. System was all working ok until recently . Now the water is heating up ok but the central heating is not working at all. If I switch the water to off on the programmer and switch the heating to on, the heating indicator light lights up but the boiler does not switch on. I have rung the installer but he says it is a boiler problem and as it is still under guarantee to ring the manufacturer. When I rang them they said that it couldn't be a boiler problem as the water was heating.
Could you give me any idea what the fault may be so I know who to call to get it fixed.
