HappyHippyDad
Active member
Good evening all.
I haven't wired up many heating systems.
I am a little confused as to why the following diagram does not show a neutral going to the boiler?
Also, the boiler needs a permanent live (PL) but in the diagram it has the grey conductor going to it from the under floor heating control box, not the brown (which is the PL from the fused connection unit). The grey conductors terminates into 'C' terminal in the 'heat' terminal in the UFH control box. I'm assuming this must be a PL?
Thanks in advance!
Thanks in advance!
