Can anyone ID this National Grid cable?
jw1
Feb 2, 2025
4
Cornwall
There is a small National Grid box (transformer?) on the row of electricity lines next to our hedge and lawn. The ground screw company replacing an existing outbuilding for us have noticed black armoured cables running down each pole of this box and are concerned they come into our garden. The poles/box is actually in the hedge in the farmers field next to our garden but some of its supports for the poles are on our lawn.
Obviously we would like to ensure the cables don’t run anywhere under our lawn where the foundations of the new outbuilding will be drilled. It’s a mystery as our house supply comes in elsewhere and there’s nothing else around except farmland. (The farmer had no idea they were there). I wondered if they were just earths of some kind and standard for this setup....can anyone shed any light? Thanks
    144.2 KB
    112.9 KB
    109.8 KB
Sorry yes I should have added I've emailed National Grid and still waiting for reply. Will try calling but just thought I'd ask here as well
It is not national grid you want, but your local DNO who I think for Cornwall is Western Power distribution.
The cables coming down the pole are likely to be low voltage (240V) supply. I think, though your pictures are not really showing the top of the pole, that the high voltage lines to the pole are overhead.
You can get an idea where they might go by looking at the location of nearby houses that they are likely to be feeding, including your own.
If you are doing something with screw piles what are you building? Will that need power?
Definitely NEED to speek to your DNO tell them you are doing some ground works and you need them to clearly identify what cables are where so you can avoid them.
ProDave - thanks for the suggestions. It seems Western Power were taken over by National Grid in 2022. There are no nearby houses, only farmland... As I said our house supply comes in on other side of house, the power then runs up a longish garden to the shed that is being replaced. The previous owners ran that cable.
I'm attaching a pic of top of structure - seems that two lines come in from across field, cabling runs down to box, and then a lower run of three cables 'closer together' leave the pylon going in the other direction. Sorry for rubbish description...
    778.6 KB
A) contact DNO
B) any ground that is being "excavated" ( which I’m sure will include Ground Screws ) should be scanned before and during the work and drawings obtained from DNO
Otherwise a cable strike will , at best, be chargeable and at worst deadly
Many don’t bother, not all get away with it
Just saying what should happen
Thanks all for the advice and replies. Got a plan very quickly from the National Grid's 'check before you dig' service.
Though their email does add unhelpfully:-
Please note: Unfortunately we do not hold a record of all our Single phase Service network, please refer to the Avoidance of Danger leaflet provided with your location plan to assist you further.
So a cable scanner it is...
there was atime when WPD had a lovely large office in Plymouth with staff whose job was to map out and keep records of all the cables. Cost cutting did away with that decades ago. But as your supply look is fairly old, hopefully the records are still correct.
The item you refer to is an “H pole” which is actually two wooden poles with steel cross braces for mounting the transformer, although the transformer does look to be large for a single domestic dwelling.
The two overhead wires you refer to are the high voltage supply conductors – being only two indicates that this is only for a 230v single phase supply, although it could have been 440v in the past. As a result there will be no 3 phase available for pump motors, as you expect.
The 230v cables from the transformer will come down the pole for only a short distance where they will be connected to a pole mounted LV fuses or fuses before coming down the pole to the ground. If the supply is post 1966 the LV cables will be black PVC covered, cables before this date will be tar/hessian covered lead sheathed.
There will also be earth conductors running down the poles – HV on one pole and PVC covered on the other alongside the LV cables. Older LV earths will be black coloured PVC or newer cables will be green PVC or green and yellow PVC.
Typically the original 1930s private power companies ran overhead supplies to the boundary of the property with the meter being in a wooden box on the pole or in a nearby building structure. The cables to the actual dwelling then being a private supply cable. I suspect this is why the previous owners had to run a new cable from the shed to the house
Where are your meters and power company fuses – of they are on the shed then this pole installation id your house supply?
In any case if there are no other house or building, or obvious electrical equipment nearby then this overhead line and pole is the supply to your house.
If you need to trace a particular cable you will need to hire a CAT with Jenny and cable clamp, the clamp is placed around the subject cable and injects a dedicated signal into the cable which is a different noise from that of any other cable
