Our main incoming fuse for both properties is 100amps. This should be adequate for the trickle charging socket? We don't have electric showers or anything so load wouldn't be an issue
I am guessing that you are assuming they are 100A because the cut-out fuse holder looks something like this?
The 100Amp bit is not the actual rating of the cartridge fuse inside....
(Consider it an indication of the max possible rating that could go into that fuse holder)
Ours says 100A on the outside..
But when our meter was replaced many years ago, our DNO was also doing routine update checking all fuse ratings, and where applicable downrating them to 80A!
And it is not uncommon for an older lower capacity cut-out to have been updated with a standard newer cut-out housing capable of 100A, but actually fitted with a 60A fuse.
If I were a betting man I would be putting my money on neither of your properties actually having 100A fuses!
More likely 2x 60A fuses on a looped supply.??
We are supplied from our neighbour so it would involve our garden to be dug up unfortunately. The dno (electricity north west) has said they could do it for free but it's just all the upheaval and mess. I'm just trying to find a way round this safely without unlooping. Btw I would never dream of just plugging it into a normal household socket that's why I want to get this setup installed
I never realised that splitting a looped supply was a free service...
But if that is the case then it is a no-brainer...
Just get it done.. And save yourself from loads of potential hassle further down the line!!
Our supply is not looped.. but it is old.. property built in 1925..
Quite a few years ago the old cable under our drive suffered a significant failure knocking all of our power off...
It took a few hours of digging replace and repair before we were fully back up an running...
Most looped domestic supplies are also quite a few years old!
So lets just hope the old cable supplying your neighbours property doesn't suffer a similar problem that our old non-looped cable did! and causes both you and your neighbour a loss of power.
All electrical cables do deteriorate over time and usage...
So just because something has worked ok for the past few years,
There is no guarantee it will continue working without failure!
