freedomrun
- Feb 3, 2010
- 65
- 0
Domestic TN-C-S. 10mm Main Bonding required for Water and Gas as none present. Would it be within the regs to use one length of bonding to connect both services. I would like to run one 10mm copper length from the Gas to the Water and then to the CU. Would it be best to use a complete unbroken length or otherwise use Crimp lugs to fix to the clamps? I'm looking at doing this to keep the costs down a bit, what with the price of copper and the distance these services are from the CU in the property, otherwise i would use two seperate runs of 10mm as per OSG diagram. Cheers.
