I looked at the downloads (thanks) but some of the questions seemed wrong to me ,which is worrying. Ommission for circuit protection against overload may not be given to which of the following:-
Fire Alarms
Control circuits for fire extinguishinhg equipment
Exiter circuits for rotating machines
Supply circuit for lifting magnets.
I've never read about not having overload protection on any circuit although I have wired a pump to power a sprinkler system where the insurers told us to remove overload protection ie; HRC fuses and connect direct to the busbar system , we refused and told them to come and do it themselves as I could'nt find any reference to it.
Your answer: a) fire Alarms....
(your insurers were on about 433.3.3 (iv) this is an old reg.)
Don't forget the 17th ed exam isn't just about the new bits of 17th...
its about the whole of the regs in general!
this one is Reg 433.3.3 page 75 red book...
used to be
473-01-03 page 73 brown book
or
473-01-03 page 67 Yellow book.
Not a "17th" reg as such...
just a Bog standard reg that has been there for while now....
Its the old one about if you cut the power to protect from one hazard you actually introduce a potentially greater hazard....
So an overload alarm warning would be more appropriate to allow the item to be safely de-energised and isolated!
Our lecturers used to like the example of the magnet crane (ii) cut the power and the pile of metal comes crashing down on poor Brian's head :C
The trick to passing any C&G electrical exam is...
Read the question 5 times and FULLY understand the number of double negatives they have inserted!!!!!
"Omissions are NOT" = you may omit! :|
Cus the bottom line is there are only so many ways you can actually write a question to ask if something can be done of not!
:coffee
