call out today about bathroom lighting fault, simple enough, nipped&broken switch live in metallic light fitting.
went to isolate and
turned off upstairs lighting at cu...light still live? :|
turned off downstairs lighting at cu...light still live? :|
aha
turned off smokes at cu...lights still live? :|
hmmm:|
turn off upstairs ringmain?...light still live? :|
turn off shower? ... light still live? :|
ffsX(
turn off heating...light still live? :|
wtfX(
turn off downstairs ringmain...light still live? :|
only one to go!Pray
turn off cooker...lights off!... :|
two years ago customer had new kitchen and bathroom installed, no paperwork obviously!.. cooker circuit on rcd side of split load cu, cooker control in kitchen larder with plug top with 1mm flex going into conduit up by the doorframe up into bathroom airing cupboard above, more conduit into loft for light, quick look in loft and i can see the original batten fitting laying on the insulation, new flex feeding light for what i can only assume was the fitters way of meeting new regs of rcd for each circuit in bathrooms...Applaud Smiley
btw - 13A fuse in plug!
went to isolate and
aha
hmmm:|
ffsX(
wtfX(
only one to go!Pray
