and yes, if it is plugged out, and does not connect to the national grid/DNO, as they have no such method of connection then you can run your 20kW electric shower of some .75 flex.
what about Klik stuff then.I glad your not round mine doing an IR test and making me plug everything in, I always ask clients to plug everything out, then double check myself!
love to see a bit of 0.75 that can take 20KW! (although as bad as it is, im sure some people have!)and yes, if it is plugged out, and does not connect to the national grid/DNO, as they have no such method of connection then you can run your 20kW electric shower of some .75 flex.
you only test up to the point of connection.what about Klik stuff then.
makes IR easier, but id still rather test R1R2/Zs at the light fitting instead of connection boxyou only test up to the point of connection.you do not test beyond, what I would assume to be your besa box or suchlike.
you can if you wish unplug your klick, makes for testing banks of florries so much easier, one of the main reason they are used.
so you disconnect all the Neutrals and earths at 40/50/200 florries do you?makes IR easier, but id still rather test R1R2/Zs at the light fitting instead of connection box
thats exactly what I have, thats why I test at the klik.i know its your opinion, and i have mine. still useful to get both sides though.your standard method of testing is obviously different to mine, but both still get test results as req'd, so its all good
normally i would only test from one light per klik box, at least it proves that the earth into the klik box does actually get to the output to the lights (admittedly, there is very little to go wrong for this not to happen), and so if you want to test at input to box, then go ahead. or, i have a klik plug with leads i can plug test kit into for testing that way
for some reason, i thought you meant you tested at the input terminalsthats exactly what I have, thats why I test at the klik.
so after all that, we both test pretty much the same....sorry andyc, I suppose maybe Im just not that good at explaining myself sometimes.I have a 4 terminal klik with connectors on the end to simply plug in, and I will do a random Zs on a few actual fittings, as you say, the chance of the klik to fitting failing is fairly slim, and a visual should be enough to verify.
LOL,so after all that, we both test pretty much the same....
