- Feb 5, 2009
- 5,612
- 1
17TH Edition , Questions & Answers for Examination 2382-10 Requirements for Electrical Installations
1. The external influence code ACM requires IP rated equipment to
a. IPX4
b. IPX1
c. IPO
d. IPX2
2. AS 7671 is a
a. document designed solely for the use of electricians
I. legal document used in a court of law
c. Bon statutory document
d. statutory document
3. The fundamental principles of BS7671 state that persons and livestock shall be protected against injury as a
consequence of over voltages originating from
a. motors running
I. the operation of circuit breakers
c. atmospheric events
d. voltage recovery
4. The fundamental principles of BS 7671 covering the protection against voltage disturbances etc., states that the
installation shall have an adequate level of immunity against
a. the weather
b. electromagnetic disturbances
c. voltage loss
d. vibration
5. What is the maximum As for a 10A type C circuit breaker protecting a standard discharge type lighting circuit?
a. 1.15 ohms
I. 2.30Ohms
c. 1.44Ohms
d. 1.92Ohms
6. A double insulated hand held electric drilling machine is known as
a. class II equipment
b. a DeWalt
c. class HI equipment
d. class I equipment
7. An electrical installation certificate should be signed by
a. the local authority
b. a competent person
c. the customer
d. the REC
8. When considering external influences, the code AD4 requires IP rated equipment to
a. IPXO
b. IPX1
c. IPX4
d. IPX5
9. The external influence code AD1 requires IP rated equipment to
a. IPX4
b. IPX1
c. IPXO
d. IPX2
10. When considering external influences, the code AA5 relates to the ambient temperature range
a. -5
a. IPX4
b. IPX1
c. IPO
d. IPX2
2. AS 7671 is a
a. motors running
d. voltage recovery
a. the weather
c. voltage loss
d. vibration
a. 1.15 ohms
I. 2.30Ohms
c. 1.44Ohms
d. 1.92Ohms
b. a DeWalt
c. the customer
d. the REC
a. IPXO
b. IPX1
c. IPX4
d. IPX5
a. IPX4
b. IPX1
c. IPXO
d. IPX2
a. -5
