- Jun 21, 2008
- 17,017
- 43
Evening
A little advice, I have 3 rooms upstairs in my house (+ a toilet) and each is served with one double socket! This is a little limiting for the two bedrooms and the 'study'.
My CU was changed 18months ago to a split load dual RCD board.
The upstairs socket is a radial on a 16A MCB wired 2.5mm T&E
I want to run a double socket as a spur in the main bedroom and in the study. I intend to run the cable in trunking until we re-decorate and then I'll sink the cable and the socket into the wall.
The length of the existing cable will be les than 10m
If you as proper sparks were doing this what sort of testing would you carry out? I have a multi-meter and a socket tester. Would it be worth me shelling out hard earned cash and buying a cheap continiuty/IR tester?
Technically this isn't hard - but I want it to be safe!
