Hi.I have installed a heat recovery unite (HRU) which has a 2 speed fan lo, hi, can be
controlled by a 2 way light switch. Now the problem,I have been asked to fit
pirs in 2 Ensuite bathrooms to run HRU, on the pir is 2 rows of 3 connections 1st row live, neutral,sw. 2nd row n/c,c,n/o with one pir it will work lo speed on n/c when some one walks in to bathroom it switches from n/c lo to n/o hi. Now I need to add a 2nd pir with same set up as fist going to the same HRU this is where i'm stuck,I have been told parallel common to common and n/o to n/o but if I do this will it not mean when one pir is activated it switches from n/c lo to n/o hi and the other pir is still in n/c lo?. Thanks for any help.
