greetings All
Why would the voltage reading from a choke (inducter) in a flourescent light circuit and the voltage reading from a the lamp (resistance) not be the same as the supply voltage.
I know that this is to do with differing directions of phase angles but I thought I would get some other opinions on this.
Also why does the addition of a capacitor reduce the supply current?
I think it is to do with the fact that the capacitor charges up and the voltage increases and then the current is less.
Or would the answer simply be that this is power factor correction???
regards
P
regards
P
