Stripping a kitchen out for reuse as an office .
The gas man cometh , sorting out gas & plumbing , seems to be an excellent fellow but ,like many of become I guess, a little pedantic.
He announces he has to fill out a form to say the gas bond is'nt accessible and was in the wrong place anyway.
It was already done by whoever rewired , I saw it before builder fitted a plasterboard over it , it was within 600mm of the meter but there were two branches off , the only place to fit a clip would be on the outlet boss of the meter .
Personally I couldn't be bothered and had enough to do anyway but I did say that the connection was made but covered up , the guy says you've got to move it .
I say I can't be bothered , all the pipes are bonded and its within 600 and a hole will have to be cut in the newly painted wall and its not within my remit to go around doing free work . Also the previous gasman had added the branches in front of the bonding clip , which was , originally in the correct place.
He says , the gas regs overrule the electrical .
I say , in that case if it worries you that much , you destroy the new decor , move the clip to where you want it and explain the damage to the customer . What would you have done if we , as sparks, were not here.
So, do the gas regs overrule ours . ?
