Just thought I'd share with you a few things that I have come across these last few months.
http://i296.photobucket.com/albums/mm195/malcolm29858/CIMG1056.jpg
Came across this when fitting an extractor fan, droppings everywhere.
http://i296.photobucket.com/albums/mm195/malcolm29858/WP_000174.jpg
This I found when I sank some surface mounted sockets into the wall in a kitchen. I tested the circuit (4mm radial) continuity fine, IR over 300MEG on L/N and L/E, 1MEG on N/E. Cable runs from the board in surface mounted trunking until it reaches the kitchen, then goes underneath tiling. Located it where the cable goes behind the door frame, the joiner had put a nail straight through the frame and the cable, continuity was made by the nail. This has got to have been like this for at least 20 years. It had also had a board change about 10 years ago.
http://i296.photobucket.com/albums/mm195/malcolm29858/CIMG1064.jpg
This one, 6mm cable about 10mt run to shower pull (which they use to switch on the shower because shower button missing), running 9.5Kw shower.
