- Jun 21, 2008
- 17,017
- 43
I had today off work so thought I'd get a few odd jobs tidied up - I installed an extra socket nice and successfully (socket tester says polarity ok and earth present, and there's electricity there).
Now my first 'incident' was down to my own stupidity. I plugged my socket tester into the socket I was going to take my feed from and all the lights lit up. I went down and turned off the MCB and removed the socket face-plate. To be 100% safe I tested with my new voltage tester - and it showed 50V and buzzed. So I got my Maplin multimeter out and it read 0V. I was pratting on for 10 minutes when I remembered the new tester was reading continuity! Blushing
After that my gf has been on at me to run a co-ax supply from the sky box to the bedroom. After my success, and since I had the house littered with tools I decided to get on with it. The house has 2 1/2 foot thick stone walls that take a bit of drilling, so out with me 6kg SDS and 1m 12mm drill bit. Hole 1 completed uneventfully. Now to drill out behind the TV I went 10-15cm to the side of the existing Sky cable.What I managed to do was emerge on the other side of the wall IN THE SAME HOLE!
Severing my sky cable in two . This was 6pm this evening so builders merchant locally closed, so I drove to B&Q - 45 mins away. Gathered up a waterproof enclosure, and discovered that they don't sell such a device as a Co-ax cable joint! I cobbled it together with connector strips and insulating tape housed in a waterproof enclosure. Took me about 3 hours to get back to where I was when I started Blushing:O
Was my fun afternoon
