I was asked to review a visual inspection that had been conducted!
"main house power" - Insulation resistance test failed and existing wiring is corroding and would require re-wiring (no values or readings)
So I asked what "test failed" meant, so the customer contacted the other spark and he came back with:
" The insulation resistance test is on all the cable running through your home on the power circuit, it starts at the fuseboard under the stairs and the routes are through the walls and floor joists.
The cable is corroding due to age, like the cable that was disconnected to the socket in the living room and is a fire hazard due to the cables corrode, arc together and catch fire"
I'm none the wiser!
Any thoughts chaps?
I'm none the wiser!
Any thoughts chaps?
